E350 w221 om642 does not crank
ruse77854
Vito
Hi, i have e350 mercedes, parked my car and after few hours wanted to start and heared click click and does not crank, i have checked in live data IMG_4330.jpeg and i dont have circuit 50, replaced relay and does not work
Doug1234
Bedfordshire uk
1997 w210 e300td
Reach down if you can and get hold of the starter solenoid connection , don’t pull it off but wiggle it around / and also try to push the wire into the plug and then see if the engine will start.
My Jeep with the om642 ( grand Cherokee 3.0crd ) mines a 2006…. but all the 05-10 diesel models suffer from the same problem which is the solenoid wire connection is not crimped securely enough inside the plug from the factory.
This may not be your problem but 90% of diesel grand Cherokee’s eventually suffer from this problem leading to just the relay clicking and no starter operation.
Access to the plug is probably going to be harder than on my Jeep which has more room and no air filters down each side of engine. , so if you can reach it just be careful not to fully pull it off as you may end up taking under trays and all sorts off to get access to get it back on
R
ruse77854
Vito
I have tried something else, i used on the solonoied plug Inspection lamp and tried to start the engine and doesnt have light on the Inspection lamp,
