DaveE320CDI
While your waiting to get your THIN WALLED deep socket spray plenty of WD40 or similar down there just in case the actual sensor is seized in the engine
have you got the bolt out ?
if not hit the head a few times to shock the bolt lose, also use plus gas rather than wd40 its immeasurably better at penetrating through the rubbish
if the housing is aluminum you could use a heat gun carefully to warm it up to get a bit more room to remove the old sensor
Scary business , me E class took half hour the other week to change the cps . Going to do the CLK at some point , but seeing your troubles I think I’ll wait for next summer when I don’t need the car for a week . Good luck with it all .Not got the bolt out yet. I shall try the shock treatment and soak it in plusgas during the week.
Funny how you forget the basic things as time goes by. Sort of gave up mechanics about twenty years ago but have enjoyed some of the work I have done recently so though I’d do this easy job !!!pah.
I did try putting some bristles of steel (ex wire brush) inside the socket to pad it out in the hope that it would grip if I tapped it onto the bolt.
I shall try the tap the bolt first then the tighten it a nip, another way to break the grip.
Not sure about the heat though, not really equipped to carry that safely.
Thank you
I do... and I had it with me... I’m just a little too far away right nowI don’t have a Dremel in my armoury yet.
Unfortunately I can’t take the day off as I’m not in work... If I was I’d be happy to^ At the very least you should take the day off and run the Dremel down to Gosport.
It's what a moderator should always do for a member in need.
That’s sounds like a classic Catch22 scenarioUnfortunately I can’t take the day off as I’m not in work... If I was I’d be happy to
Are there sockets on the market that are designed to grip rounded off bolts , it does vaguely ring a bell that I’d seen some beforeThank you,
The bolt is tight. I have had a good purchase on it and having thought I’d moved it, I hadn’t. I have a good gripping socket if I can get access to it so will try to remove the sensor. Will spend the next few days applying plusgas to it.
I’m not one to give up and luckily I don’t need the car as have another.
What’s the latest buddy , any luckI have a socket that will grip most shapes, but as said need to be careful not to sheer the bolt when using it. If I can remove the sensor I shall give it a go.
Not heard of Irwins, I know the name from tools but,
As for the Dremel, not sure it would be able to be used as is limited space though not familiar with the tools that can be used. No rush for the road trip Russ, but thanks.
