eco sign on dash
hmang
I cant tell if its yellow or green i might be a bit colour blind
should it be really obvious ?
not even sure what it does to be honest
s350cdi 2013
AlanGunn
Anglesey
2013 C250 sport+ 2.1d
Yes.
If you think it's green then come to a stop and see if the engine stops.
H
hmang
Oooh
I’ve never had stop start
Wonder why it’s not working
Any ideas
AlanGunn
Anglesey
Batteries need to be in good condition and fully charged.
H
hmang
Ok new battery
Do I need to reset something?
AlanGunn
Anglesey
Replace like for like nothing to do after.
steveq
Dublin
2011 Merc S212 E220CDI Estate; Tesla Model 3; 1965 W113 Merc 230SL Pagoda
The stop/start only goes green when a number of criteria are met.
Some of them are that the car engine must be at or above a certain temperature; the car must have been driven at above a certain speed; the services load (air con, etc.) must be below a certain level; the outside temp mus be above a minimum; etc., etc.
If you have the air con on it probably will never go green -- hence it doesn't kick in much or at all during winter.
AlanGunn
Anglesey
Mine kicks in after half a mile first thing in the morning.
I do keep the batteries topped up if the car is not in use for a week with a charger/conditioner.
steveq
Dublin
You're doing well.
Is that with heater/climate control turned on?
AlanGunn
Anglesey
Not often i use ac heater is set on 24 at the moment fan on II.
If i have done a load of short trips it will stop working after a few days but doing my normal 50 mile round trips it works within a mile at the most from starting the car and driving off.
H
hmang
Nah .It's not working .
I still can't tell if it's green or yellow
It's not as green as the indicator telltale, but it's not as yellow as the engine warning light .
there's no mention of stop /start in the steering wheel /dash menu
AlanGunn
Anglesey
Don't think there is any mention of it on the dash.
Have you got a charger you could put on the car for 24 hours.
It would charge the other battery as well as that one needs to be well charged.
steveq
Dublin
Is there an "ECO" button on the central console?
Here is a short video of its operation:-
It is for a C Class and it is the same on an E Class.
I'm not familiar with the S Class though -- it might be different.
H
hmang
Big battery is new today
Aux should be ok
It’s done 200miles a day for the last few weeks
I have noticed a low voltage warning when connecting the diagnostic sometimes and sometimes it shows a terminal 15 fault
I do have a fault with the central gateway but can’t seem to find any info on how to deal with it .
H
hmang
  • #17
No eco button that I can find any where
steveq
Dublin
Here is a video on the S Class.
In it they are showing an ECO button on the central console.
It is a US video so might not be on all S Class models worldwide.
Do you have the car long and if so has the ECO mode ever worked?
I remember reading that some people (who seemed to think the Stop/Start was the work of the devil!?!) discovered a way to ensure that it never turned on. I don't know what 'Terminal 15' is but that might be related -- maybe a fuse was removed?
H
hmang
  • #19
I’ve had it a few years now
The stop start has never worked .
I’m not even convinced it’s fitted .I don’t have an eco button
Only an eco light on the instruments just under the gear position indicator
AlanGunn
Anglesey
How many gears has it got.
Got it in my head that 7 speed and up have ss.
