Engin swap
chrisskinner
www.mercedescosworth.zoomshare.com
I currently have a 190 E 1.8 and i want to take that out and put in a 2.5-16 cosworth lump. Just a couple of things i need to know will the cosworth lump fit straight into my car and will i need to change the wiring harness cheers in advance for any help recieved
though I cant say about the harness, it should be compatable, you will need the ECU from the Cosworth engine, It will drop straight in.
malcolm
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
I'd hazard a guess that the exhaust, radiator and possibly the gearbox will be different. You need to look up some part numbers for 1.8 and 2.5-16 ancilliaries to see if there are differences. You may even find that engine mounts are different
If one car has aircon and the other doesn't, or one is auto and the other is manual, then expect your problems to increase greatly
The 7P rule applies here
Nick Froome
www.w124.co.uk
Stevie A
Scotland
Exhaust is bound to be different and are there not heavier springs on the bigger engine models? Fuel tank on a 2.6 is bigger than any other models, but that shouldn't matter too much.
I would leave the 1.8 in it and look for another 190E with a bigger engine.
jberks
I'd imagine you'd also need to uprate the brakes, wheels and suspension too, just to make it safe, let alone road legal. Then what about the interior? Also check the implications on your insurance - chances are you'll need a specialist. After all that, you'd probably be better (cheaper) buying a proper cossie in the first place.
C
chrisskinner
i have already thought abut exhaust and brakes and the such like and i have a nice big list of things that will need to be changed. The exhaust will be changed for a one off stainless steel system made to fit the car. All i really needed to know was about the harness
