Engine and Transmission Oil Recommendations
grubber
2004 W211 E320 CDI
Hi All - What make of engine and transmission oils do you recommend for W212 E350 Estate?
MB or Fuchs (who may supply MB ? ) for ATF
gianton
Thessaloniki, Greece
S213 E 300 d 4M - 04/2023
I use Fuchs for both and change them earlier than recommended (every 5k miles for the engine and every 45k miles for the 7g+ gearbox).
G
grubber
2004 W211 E320 CDI
Thanks. Which specific oils do you use for both engine and transmission please?
Chrisoops
CLK350 cabriolet elegance 2005 3.5l V6
I see for my CLK 350 MB lists engine oil 229.5 or 229.3. Can anybody throw light on the difference? I see most posts mention only 229.5.
The 229.5 is the latest incarnation, go for that :D
M80
Derbyshire
229.5 is engine oil for cars with no DPF, as it has a higher ash content.
It isn't as readily available as 229.5'1' anyway and the 229.51 is good for both with and without DPF.
229.5 will harm a DPF.
Is 229.3 still available? I don't see the point in considering it even if it is.
The last time I bought some it was 20 litres of Moteronol (Petronas) 229.51 from MB Newcastle.
Delivered it was cheaper than the likes of Halfords, and a very handy 20 litre container with a vent to prevent gurgling when pouring.
it'll also be handy for the waste oil down the tip later.
He has a petrol CLK , so 229.5 is the right oil (but yes he can use 229.51 as well )
  • Like
Reactions: M80
Chrisoops
I can find 229.5 but at a price. I can find 229.3 at a low price but not one that's on MB's approved list. As y'all say 229.51 Genuine MB is available at a good price for 20 lt; will it be as good as 229.5 for my 2005 V6 petrol CLK? And what's DPF, Darned Pretty Fast?
M80
Derbyshire
What engine does the op have? I maybe wrongly assumed he has a CDI
M80
Derbyshire
No quite,
dumb problematic filter.
It's designed to slow you down by sapping power and use more fuel.But it does save the planet some by causing many cars o be prematurely scrapped.
Chrisoops
Thank you gents.
So, to be clear, 229.51 will be just as good for my 3.5 l V6 petrol as 229.5, yes?
No downside?
Craiglxviii
Cambs UK
Thank you gents.
No downside?
Only that normally the 229.5 is 5w/40 , the 229.51 is 5w/30 , if that’s not an issue then go for it .
Mannol do some cheap oil in 20L form that meets either spec , on eBay
