Engine noise
Max c230k
Fife
Went to drive the car today for the first time in 3 weeks (the wife hogs it all the time!!) and heard a noise coming from the enging which can only be described as sounding like a frog under the cam cover.
Got the stethiscope onto it but cant really pinpoint its origin but after a bit of fiddling around it seems more like a bad bearing vibration which kicks in at about 1500rpm and goes away at about 2000rpm.
Ill be taking off the cam cover tomorrow for a proper inspection but just curious if any of you guys have experienced the same problem or know of any common faults before a go pulling my hair out over it.
cheers!!
Oh, im driving a 1999 C230 Kompressor Sport......
BlackC55
South coast
C43
Sounds like the camshaft actuator at the front of the engine. Pull the cover off and disconnect it wit the engine running and give it a blip. If the noise has gone you know its the actuator.
hmang
hey black...camshaft actuator..? what does that do ?...just being nosey !
BlackC55
South coast
C43
From memory...... Advances the inlet cam. Cheap version of variable cam timing.
hmang
some sort of centrifugal, bobweight affair ?
hmang
interesting.
thanks guys, another thing i've learned
Glenn Smith
Peterborough, UK.
works on oil pressure, the cam and cam drive sprocket are connected via a worm type drive coupling, a solenoid operates at a certain engine speed, this moves a piston using engine oil pressure, pushing the worm drive and advancing the cam timing.
M
Max c230k
Fife
So where is this camshaft actuator??
Went back to basics and checked for all the obvious things for noises but had no joy so took the cam cover off and the noise is definitely coming from the inlet side of the back cylinder (4).
Cant see anything obvious and all the buckets are strong under pressure.
Gave the enigine a good flush and replaced the oil but it actually seems worse than before.
It really sounds like a small end bearing noise but with 102k on the clock and a full dealer service history can my trusty merc be giving up this easily??
Any ideas guys and am i missing something before i go pulling the heart out my motor?? :confused:
