such
- Nov 17, 2016
- Location
- Sunny Essex Coast
- W212 Eclass 350 CDI Sport 2012
Out of curiosity, I sent off a sample of my engine oil to millers oils. I was curious to find out if my oil changes every 8k has made any difference to the wear inside the engine.
I have been changing the oil every 8k since ownership back in Sept 2016 when the car was on 68k. The current mileage is now190k.
This is the report that was produced:
The oil sample was taken after 7k and it was MB oil bought from MB Newcastle via ebay. I have used this oil most of the time with the odd exception being Castrol & Petronas.
I have also been using archoil fuel system additive AR6900D on and off, but in every fill up over the last 10k.
As I decided to keep this car going for as long as possible (work permitting!) I wanted to check on the engine internals to avoid /predict any possible major issues moving forward.
The most notable finding I can see was the oil soot level approaching the caution limit after only 7k. I wonder what this would be had I stuck to the 16k recommended intervals and what difference this would have made to the above readings, if any?
