Jasmine
Hi there,
I have been informed by the dealership that I have an engine oil leak. They have wiped it down previously and went back for a separate matter. The dealership have no idea where it is coming from and will obviously cost an arm and leg to ask them. But on the same token they are telling me the output shaft seal is leaking slightly.
Could someone please tell me if they are related or what would they suggest I do? Most importantly how much will it cost?
Thanks.
The output shaft must be the crankshaft,, thats a strange word for it.
Its a matter of removing the damper pulley and replacing the seal. not a big job and cheaply done by an indie
teddycatkin
cheshire cheese country
What car is it ?----1st thing with an oil is how bad is it --check it every 100 miles is it losing a lot of oil or not noticeable between oil changes?
Jasmine
C Class 230 K 2001 68000 miles
RADw203
Stirling
C200K Avantgarde MT (w203)
Hiyya!! Avoid the dealers if possible. A visit to the local indie will do the trick. Also I have found Lucas Engine stop leak to be very effective. Just replace a litre of engine oil with Lucas. But treat it like an interim fix. Get the repair done as soon as you can. Cheers!!!!
teddycatkin
Just a point on these "additives"--although they are not cosidered a permenant fix they swell the seals and do stop minor leaks similar to fitting a new gasket --they can last a long long time too?
RADw203
Stirling
Hi there! It could be a hit or miss thing. In my banger VX Corsa, it permanently repaired the leak. In my aluminium block Honda, nope. It's not a problem actually as I regularly check the oil level but the trickling engine oil may find its way to some hot bits under the bonnet and start to burn and you get that smell in the cabin. Yuck!!!!
Jasmine
Thank you all for your suggestions! I'll keep you updated.
