Engine operating temp
MartinCoop
Can you help?
I suspect that the thermostat in my C class 220D (02 plate) is stuck open.
The car is new to me, so I do not know what the temp guage should show, but it seems that the engine takes a long time to warm up and does not achieve a temp of more than 60 degrees as shown on the temp guage.
The heating never really blows what I would call hot.
Does this sound I need to check the thermostat?
thanks
Hello martin and welcome to the forum,, yes that is way too cool and a 203 220cdi should run at 90c.
I have the details of how to change the thermostat if you would like it
MartinCoop
Thanks Malcolm
thats my weekend sorted out. I have a Haynes so I should be OK.
MartinCoop
One more thing you could help me with Malcolm?
Could you point me to a good on line shop where I could buy a thermostat kit?
That would be great.
Cheers
Cheers
It will be GSF, Euro, or MB there are not any others
tony2311
W203/2002/270cdi
i Just done mine this afternoon for a w203 c270cdi, got 10% discount
thermostat & 1.5ltr of coolant = £41.48 from mercedes sheffield
Much easlier if you remove the oil filter cap
MartinCoop
Its changed, but those fuel lines are brittle!!!!!:mad:
Just to calm my nerves, (drove to work this morning with my eyers glued to temp guage), what sort of range of temp should I expect to see.
ie. Hard Motorway driving
ie Congested traffic on a hot day
etc?
thanks in anticipation.
Martin
etc?
Martin
It should be around 90c
MartinCoop
Thanks Malcolm
it seems to be running at that temp now.
Let me ask that question in a better way: how hot can it get before I should get worried?
cheers
Thanks Malcolm
cheers
Lets put it this way,,I would be happier if it was over 100c :D
? Over 100?
The engine is probably running at 100,, but the point where it is measured from is a bit lower.
The most efficient temp is at over 100,, My old 1928 RR that I had, though 3 liter it was rated at 20hp, this thing only came to life at near on 100c and you had to juggle with the rad Louvre slats via the dash to keep it between 100 and 108
giuseppe
Bournemouth
E220Cdi avantgaurde 2001
you are definitely a vintage model malcolm, you will keep running for years:cool:
Peter De La Mare
15 reg E63, 14 reg Smart Passion and 64reg Caterham Levante.
My temp guage sits one bar below 100c.
MartinCoop
well mine is running warmer now, but still not at that temperature.
On my 25 mile trip to work the engine warmed up to 80 C this morning. That is a very steady drive through a 40 mile an hour set of road works on a motorway. The heating off for the first 10 minute and was set to auto 22 c, so no greatdemand.
This seems to me to be still running too cool. Thoughts?
Only the fans,,and are they working correctly
MartinCoop
The fan is not running, so it can't be that
