Engine problems after service
M80
Derbyshire
It sounds like a compression test would be useful.
Pressure can escape the bores past the pistons or via the valves.
Oil can enter the inlet tract via the PCV valve, and could have caused your over revving. Too much oil at service might find a way out that way.
I would hold back on the oil service until you've investigated the condition of your engine.
Frontstep
T210 320cdi
Does it not have a crankcase breather?
C
Celticbaz
2015 Sprinter
  • #23
Hello friendly helpful people.
Better late than never for an update and apologies if the lack of one has upset a few for some reason. It wasn't intentional to waste anyone's time and the replies were appreciated for the most part, life just gets in the way sometimes and you just don't know the circumstances of others. My Mother became ill and has since passed away so my priorities were understandably elsewhere for a long time.
Should it be of any use or interest to people viewing this thread in the future, the problem turned out to be the faulty rear ABS speed sensor as diagnosed by the local - non official MB expert via his diagnostic machine. I replaced both (to be sure) myself and the issues were resolved. I have had no sign of possible injector issues ever since either. The service seems to have been coincidental timing, however I still intermittently get the "reduce oil level" warning on the dash to this day, which first began straight after that service. Oil level had been over-filled during that service but is fine now. I will get round to replacing the oil level sensor which I'm sure this problem is related to (this particular van, a camper, is not driven very often).
My condolences
Thanks for coming back with an update/resolution
malcolm E53 AMG
Sorry to hear of your loss.
As BC above thanks for sharing the resolution to the problem
ajlsl600
france
I have now had yellow abs, tyre press sbc warnings 2 x and a few lurches which always trigger the mentioned warnings. Last time was rear right wheel speed sensor and this time front right. Yr issues in my view, unrelated oil level climbing is diesel getting in oil. Before benz wks did away with sump plug I used to just crack sump plug and see if water drops appeared on plug.
Also today these v high press injectors can leak and fuel enters sump. As previous smell it. Go from there.
