Engine ratling
Mustafa_95
Mercedes E220 2019
Hello everyone my e class w212 123k miles is making a ratling/shaking noise when i start the car especially when cold what can be causing the ratling?
Hello and welcome
Which engine do you have?
M
Mustafa_95
Mercedes E220 2019
Hi its a 2.1 e220d
Larkone
NW Essex
C219 CLS 320CDI 2008
Something loose then. Probably needs something tightening up. You need to do a bit of investigation as to where the noise is coming from exactly otherwise we can only randomly guess as to the cause.
daveenty
The Frozen North :(
2019 AMG S Class Coupe
This answer is basically correct though I'm going to make a random guess anyway and suggest that the engine mountings are worn.
Larkone
NW Essex
or a broken/missing exhaust mount
Larkone
NW Essex
or a worn pulley on the serpentine belt
A.J.
Norwich. UK
Could be anything then ? Mustafa obviously needs to drop into an Indie to check it out :)
V6Matty
Newark, Nottinghamshire
OM651 so could be impending doom as chain stretched and cams have worn already jumping a couple of teeth.
Kev555
N.I
Could be heater plugs or injector problem as well. Visit to garage recommended
Rappey69
hants
c220 w204 amg sport
Could be the airfilter assembly.. that makes a terrible low noise when its not held on properly.
I think the op needs to post a video so we can hear what type of noise it is ?
