Engine shaking while idle or low speed
kmc9
2014/ C Class
Hi all,
I am trying to figure out the problem with my car.
It is a 2014 C 180.
Since last few days, it has started to shake a little while standing idle or during driving with low speed or a couple of times, it did the same while I was applying brakes.
It has also been showing this warning message with battery that states, Stop Vehicle, Shift to P, Keep the engine running.
Can someone help me in figuring out the issue please?
I tried to browse online and in few instances, the issue was with EGR valve. But almost all of them were older than 15 years.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Charge the battery up and see if things improve.
K
kmc9
2014/ C Class
I will try that over the weekend.
It has been -21C here, do you think a frozen air filter could also be a reason for the engine to shake and try to pull air through it?
Unless it was completely soaked and it froze no... unless you've been driving through Rufford Ford too fast then the air filter shouldn't get wet...:oops:
onefortheroad
uk.
When they tell you to pull over with the engine running , it's usually battery related or it's a very scenic area
malcolm E53 AMG
Where are you -21C can cause a few electrical issues especially battery
K
kmc9
2014/ C Class
