Engine Temperature - in this foul weather
Status
Not open for further replies.
ae1hini
5711N
Location NE Scotland, Weather ***te, 190e 2.0 normally runs at around 80 Deg, in this awful weather it is struggling to hit the 50 Deg mark which impacts on the heating output!! Are these temps normal?
As the result of a high speed argument with a pheasant earlier this year the RAD is only about 5 months old.
dave elcome
Maidstone kent
Engine Temperature
Sounds to me like the thermostat is knackered, and therefore opening a bit early, try changing this first, its the easiest and cheapest option.
good luck.
sunil sood
Engine Temperature
your car is running too cool,therefore either your thermostat is stuck open all the time resulting in overcooling,or your engine fan is on all the time,check it with the engine switched off ,the fan should freewheel if you spin it by hand when the engine is cold.(that is if your car has an electomagnetic type clutch fan)
another possibilty is that the thermostat is missing altogether-are you sure it was replaced when your rad was changed
NormanB
Portsmouth UK
Engine Temperature
Agree with Sunil and David - it is most likely to be your thermostat - which is an easy peasy 10-15 min job.
Even if your fan was running continously yr thermostat should shut down flow to rad and maintain engine temp.
I have recently done mine, one of the support legs had failed in way of spot weld, so the guts were all hanging over to one side and the poor old thermo had no chance of doing very much.
NormanB
dave elcome
Maidstone kent
Engine Temperature
Heed what Norman and myself have said, thermostats are not the fit and forget thing that most people will have you believe, they wear with use the same as all other mechanical devices.  Also your stat is not "missing" nor is it "stuck open" as others have stated, if this were the case then it would not merely run cooler, it wouldn't reach temp at all!!
(Edited by dave elcome at 6:34 pm on Oct. 23, 2002)
nickh
Engine Temperature
my 23e takes a long time to reack 80 degrees now the weather is cooler, and it reaches 100 if i,m stuck in traffic for a while before it cools down, does this sound normal? should i replace my thermostat?
NormanB
Portsmouth UK
Engine Temperature
Hi nickh
Thats a tough one - mine takes longer to warm up too!
The question is how long is too long - unfortunately too many variables for a simple answer. You are probably the best judge (what was it like last year when temps similar?).
You could give it a stiff ignoring - at least your engine  is getting to operating temp OR you could spend a few quid and swap the themo out.
I suppose you also blank the bottom third (with cardboard) of your radiator - shouldn't need it in winter - particularly if you are just doing short trips. I expect some experts will descend on this paragraph and urge caution.
Good Luck
sunil sood
Engine Temperature
my gut reaction tells me that the 100 degrees in idling/traffic is normal
A
ae1hini
5711N
Engine Temperature
Thanks for all the comments so far, what is a reasonable operating temperature?
sunil sood
Engine Temperature
a reasonable operating temperature would just above the 80 mark on the temp gauge.this is while driving along,in traffic it may rise to half way between 80 and the 100 mark-experience from my car
sunil sood
Engine Temperature
Status
