Engine won't stop!
mjhmjh2
Just welded up a small hole I found on the drivers side inner wing.. Now when I go to stop the car it doesn’t, the engine keeps on running. Coincidence?
I tried to see if I could find a fuel solenoid but had no joy. Is there one somewhere and if there is, is it electrical? Is this likely to be the problem?
Oh she’s been running on commercially bought biodiesel if it makes any difference.
Any ideas what or why it fails to stop when you turn the ignition off?
Matthew
1988 250TD W124
Ellsy Tanners
Mars
Properly melted a vacum hose which is reqiured to shut down the diesel pump.
M
mjhmjh2
ahhh. so that's why I can't find any electrical connections going to the pump.
Is there a schematic available showing the layout of the tubing?
Matthew
Ellsy Tanners
Mars
Someone may have it, or if you go on the russian parts site and have a look that should give you an idea. I dont know how to but links on but somebody will do!
His problem is solved as he melted a vacuum pipe. this car has a vacuum shut off
For anyone else that has a problem there is a red manual shut off lever on the inlet side of the engine
M
mjhmjh2
now this is really daft.. I fixed the problem this morning.. I'd not melted a pipe after all - rather when I had tried to move the vacuum pipe out of the way I'd managed to pull it off the back of the headlight!
I tested the theory of lost vacuum by seeing if the headlights moved on their switch (or not), which they didnt
thanks for your help
Matthew
