EPC on 320cdi 51 plate
aa1
I am experiencing problems where under hard accellaration the engine cuts out, all ignition lights come on and I get a warning message EPC light as well. All I have to do is turn the ignition off and on again and the car returns to normal. It performs perfectly under normal circumstances but I tow a caravan and sometimes a bit more throttle is required and then it can become dangerous. I have not had the car to the dealer as yet but wondered if there was any well known problem which I coud look into myself. regardsAA
INKJET
I am having a very similar problem on my 320 CLK when you kick down in either S or W mode and hit 500rpm i get the ESP & BAS lights on and car goes into limp mode, stop turn it off and it fine again, until you hit 5krpm?
in the main dealer on Wednesday
A
aa1
I would be interested in hearing what the outcome is. regards AA
Rob 210
west london
W210 T 320 cdi and now a 320 129 sl
I've had the "Triangle" light up - I worked out that it meant I was losing Traction and should modify my driving style
Cosworth
Get the car plugged into a star diagnostic machaine and it will identify the problem
Myros
R107, S211, R170, C219
you'll probably get fault codes
for charge pressure control, pedal value sensor, and mass air flow sensor, amongst others.
You can take all these off and clean them up or replace them easily enough. You should check the air filter indicator on the housing. If it's showing red or part red, dismantle the housing and check the filter isn't snafu'd with leaves or mice nests or some other obstruction. Also check that there is nothing loose in the housing that can block the airpath.
don't forget the brake pedal switch. It can be a culprit in this kind of behaviour and is cheap and easy to change.
simon winn
oxford
just cured this problem with a new pedal sensor - part no 542 33 17 -£103.21 + vat - under bonnet part of throttle assembly.
Hi Flyer
E270 CDi Avantgarde Estate (04/04)
Similar problem on E270 CDi, but no cutting out completely - yet! Just very sluggish on kickdown and limited top speed.
Any thoughts gratefully received. Booked in at dealer on Monday - they can look at the rust on the tailgate at the same time!
