mark mercedes
- May 30, 2009
my e230 est 1997 is pinking under load, engine top rattle heard. also engine speed hunts wildly at start up, between 0 - 1000 rpm indicated, but settles down after a few minutes. local garage found ecu readings all at zero. recommended replace ecu but unsure it would be the final solution. can you advise? although very supportive at the local garage the mechanics think this could be the beginning of a costly if not terminal journey; loathed to let the old beast go, so would like some help!!!
yours mark
yours mark
