Esp inoperative w203. Steering wheel misaligned. Is garage at fault.
zuberali
W203
Hi all
I have a Mercedes w203. I sent it to the mechanics to change the ball joint. A day after receiving the vehicle back I noticed the steering wheel seemed misaligned and now I have a 'ESP inoperative error see owners manual' show up on the dash
Now did the garage do something wrong or forget to do something as it seems suspicious that the error showed up 1 day after the mechanic changed the ball joint. Or is it just coincidence
mioba
Nottingham and Köln
Take it back to the garage as ask them os what I would do.
star
Reading
Smart + others :)
I expect the arm has been fitted incorrectly, especially if has adjustable camber/caster bolts fitted. Or they have fitted the wrong or cheap arm.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Steering angle will be out .. ?
bladecrazy
bolton
tesla model 3 performance /honda cd175/w123 300d gertrude.
yes the steering will be out so steering angle sensor will through a fault, go back and show them the steering..
mersum1es
Finland
and say NOT to adjust steering wheel... ;)
mersum1es
Finland
Sorry so you mean tell them they need to adjust the ball joint not the steering wheel to auit
Exactly! NO STEERING WHEEL, EVER!
Cheap arms always do it! Fit MB Oem or fit cheap arm and do geometry alignment.
Z
zuberali
W203
Noted. I'm not mechanically inclined. I just give it to the garage and expect them to do it right.... guess not
We always try and give customers both options. Some arms need the bushes as well, and are quite expensive compared to cheap aftermarket (£90 vs £300), but have to keep in mind the cost of alignment on top of the cheap arm..
