failed water pump?????
eddiethemerc
middlesbrough
Hi every one, Took my w202 c250td out today.......looked at the temp gauge after a few gours and it was way hot......plenty of water still in(most of it gushed out as i tried to "slowly" undo the cap. The heater was cold and the sid viscious fan was that viscious..i jammed the fan up using the old knotted rope trick but it didnt really help......It was above 80 on the temp gauge and after about two miles of running, would shoot up really quick....stop...let it cool down and it`d be ok....i`m thinking the impeller has came off the water pump shaft? Am i being thick? is this common? CAN ANY ONE PLEASE HHHHHEEEELLLLPPPP!!!!
Aussie Nick
Melbourne...Australia
Any bubbles in the coolant after you have turned it on? Any moisture at the exhaust outlet and how much? What is the colour of the engine oil when the car has been sitting idle for some time with the engine off and is there any increase in dipstick level?
star
Reading
Smart + others :)
The impellor can split as its only plastic, only seen it on E300d, try themostat 1st.
Cosworth
Yes my friend had the same problem, he nearly ripped all his hair when he changed the
1) Radiator
2) Visous fan
3) Thermostat
After all that still the same. Turned out that the impeller on the water pump had broken.
Get that water pump changed.:D
star
Reading
Smart + others :)
try stat 1st as its cheaper and easier.
shibb
New Registration
just replaced my water pump C220 w202 yesterday. it is an easy job ( if you can get the fan off!!!!!!) £28 GSF. water was coming out from behind the fan mount running straight down the belt and spraying like a mother. but hey its all fun. just thought id let you know were to find a cheep one.
mattkh
England
A160 W168 1999 1.6
just replaced my water pump C220 w202 yesterday. it is an easy job ( if you can get the fan off!!!!!!) £28 GSF.just thought id let you know were to find a cheep one.
Were the vanes of the water pump plastic or metal ?
