Fault accident should I get repaired or written of
Sham80
Mercedes c class executive edition
Hi I’m so confused as they are wanting to repair my merc c class 2018 plate but I’m worried I won’t be able to sell the car In future it will be hard to sell a repaired car I think it’s written of but they said because airbags didn’t go of might be repaired I’m with insure the box feel pressured with them it’s not a cheap car so don’t to lose out
A properly completed repair should be virtually impossible to detect to anyone but an expert.
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
There will probably be a paper trail
of it involved in a repair if it’s that bad you think it should be wrote off ,
But if air bags are intact then it must only be external skin damage and as said the repair should be 99% impossible to see . The part I hate is sometimes after a car gets a hard enough knock body seals can get broke and the car tends to steam up more often due to this. Was the accident other persons fault. As then there is possibility you may be getting
compensation which may help make it
bit easier to bear.
Sham80
No accident was my fault yesterday lost control after braking wen suddenly fox came as I turned corner of bypass to join like a slip road and it happened so quick I ended up hitting bridge I have pics if it would help
00slk
Cambridgeshire UK
you would have got away with it if that darn bridge wasn't there :D
mercmancdi
And sometimes there are descent repairers :coffee:
Agreed which may be a lot cheaper too ,
But if going through insurance best to try to get the very best available if possible.
Sham80
So is a repair car hard to sell will it lose value
js190d
newcastle
1991 w201 190d 2.5/ 2002 s210 320cdi avantgarde
The cars value will depend on if it is assigned an insurance category once repaired. This will go on the V5 document so cannot be hidden.
Sham80
Now I am worried I will lose out if I sell privately later on
I think you're worrying unnecessarily. Unless your car is written off, which it sounds like it won't, then any future buyer will be none the wiser as the V5 won't have anything to indicate it's been repaired.
js190d
newcastle
Speak to your insurance company. If they repair car then it should not be assigned a cat marker.
I will say it is usually pretty easy to spot a repaired car though.
Alistair, you're going to the wrong repairers :rolleyes: :D :p
descent
/dɪˈsɛnt/
noun
  1. 1.
    an act of moving downwards, dropping, or falling.
    "the plane had gone into a steep descent"
decent
/ˈdiːs(ə)nt/
adjective
  1. 1.
    conforming with generally accepted standards of respectable or moral behaviour.
    "a decent clean-living individual"
  2. 2.
    of an acceptable standard; satisfactory.
    "people need decent homes"
00slk
Cambridgeshire UK
descent
/dɪˈsɛnt/
noun
  1. 1.
decent
/ˈdiːs(ə)nt/
adjective
  1. 1.
  2. 2.
Pickkie pickkie pickkie :p:p:p
Makes a change usually it's JL hitting me up for spelling :D :rolleyes:
