UKMarine
I realise that I’ve posted this as a post in a thread elsewhere on this forum but I thought I’d reach out to the wider audience that might not see it otherwise. The 55 plate S Class S320 cdi (OM648) I bought recently with work needed to be done was smoking with stinky diesel smoke so I knew that I had a problem with my injectors and it turns out that they are for an earlier model (OM613), anyway the details of my post are as follows....
I’ve had a carista bluetooth obdc reader that was used on my Saab laying around for a while and thought I’d try it on the Merc just out of curiosity to see what it would report on the el.power EPC fault, and it came up with the following -
P0201 - Injector Circuit/Open - Cylinder 1
P0202 - Injector Circuit/Open - Cylinder 2
P0203 - Injector Circuit/Open - Cylinder 3
P0204 - Injector Circuit/Open - Cylinder 4
P0205 - Injector Circuit/Open - Cylinder 5
P0206 - Injector Circuit/Open - Cylinder 6
P1405
P0404 - Exhaust Gas Recirculation "A" Control Circuit Range/Performance
P2033 - Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 2
P0428 - Catalyst Temperature Sensor Circuit High Bank 1 Sensor 1
OBD2 - pending:
P0244 - Turbocharger/Supercharger Wastegate Solenoid "A" Range/Performance
Now I know the injectors are the wrong ones for my model of Merc but I don’t know if I’m impressed the car knows that they are wrong.
Any further info anyone can give regarding the other faults will be gratefully received. I have looked them up but it’s always better to hear from someone that’s had experience of one or all of the faults. Having had many cars that have had many faults reported I am aware that they are probably cascading from one originating fault but it would be nice if someone could point me in the right direction.
Many thanks
P1405
OBD2 - pending:
Many thanks
