rich.g.williams
- Oct 25, 2009
- Location
- Cardiff, South Wales
- C200 Kompressor Coupe 2003
The serpentine belt on a typical Mercedes car can drive as many as eight pulleys. Alternator, Water Pump, Crank Shaft, Power Steering Pump, AC Compressor, Kompressor, Idler Pulley Wheel and Tensioner Pulley Wheel. At best finding which Pulley (which Bearing) is creating noise is no easy task. Adding to this, modern Alternators have a freewheeling pulley called an Overrun Alternator Pulley and some AC Compressors have a freewheeling pulley that locks when the AC Compressor is in use.
Faced with something very noisy going on I followed the following procedure with varying degrees of success:-
1. As always remember that the serpentine belt when an engine is running is a serious hazard so whatever you do work carefully.
2. I removed the serpentine belt completely and ran the engine for a short time - the noise went away completely proving that the cause was not elsewhere.
3. I recorded sound from nearby pulleys using my mobile phone - didn't help much.
4. I used a long steel bar to listen to bearings - didn't give conclusive results for my noisy pulley problem.
5. I made a temporary belt out of a Bungy Strap - cut the end hooks off and superglued the the Bungy ends together, then threaded it from the crankshaft onto each pulley (including idler and adjuster wheels) in turn, (left the Power Steering pump till last knowing that it would wear my Bungy out quickly) - didn't produce conclusive results for me but would do for several problems.
After all of this I decided to replace the Power Steering Pump, that made no difference at all. Suspecting the Alternator next I came across a YouTube video about the Overrun Alternator Pulley, that made sense as the likely cause and sure enough the Overrun Alternator Pulley was seized up and rusted solid. Removing the Alternator and then removing the seized up Overrun Alternator Pulley were far from easy tasks but the new Overrun Alternator Pulley cured the problem and the noise went away.
How do professionals deal with this?
Photo of the "Bungy Belt" turning the Alternator and the Water Pump at the same time, shown in use below:-
