Fitting side window to R129
Lurchio
Hi, everyone! The front passenger side window on my 1991 500sl was badly (and I mean badly!) scratched, as it had been lightly used, but scratched by trapped debris in the seal. I've got the seal spotlessly clean and been lucky enough to source a used (but excellent) window glass, complete with mounting rail from ebay. I can do the door card thing, thanks to info from yourselves. Anybody got any tips for fitting the new glass? Do I need to adjust the riser rails after fitting? Any tips gratefully received, thanks in anticipation!
I can give you this info but what 129 is it please a 129--- and the next 3
L
Lurchio
Thanks, the vin says 129066--------- The side window came out of a 'broken' 1995 320sl, and I am assured it will go!
Cole@MBS
www.mbssouthampton.co.uk
They are a work of art to set up correctly!!
I have sent 3 Emails and this should see you through the job
L
Lurchio
Malcolm, I can't thank you enough, I am very grateful. If I can do anything for you...... (but I doubt it!!!!)
Its a pleasure,,you may need some more info on setting the glass up as SAM said.
The main thing is,,all of the window rail fixings will have left a mark as to where they were, so when you do up the fixing screws, if you use the existing marks you will not go far wrong
