Flat battery ?.CLS
peterwhayward
grays essex
E240 classic est 2000 2.4
Hi, beginning to think this car is jinxed. Not been a good story so far.!.
Just got a call from my wife...........the car wont start. Shes parked at Lakeside.Picked her up and brought her home.
now I'm pretty sure its a flat battery as shes been using it for the past two weeks for nothing but commuting to work and popping round the shops/daughters/mates etc.Had to get in the car by using the manual key and then the alarm goes off very weakly............am I probably right about the battery?. Will call the RAC out (again) to try and get it up and running in a couple of hours time when they are not so busy.If it is the battery will they need access to anything other than under the bonnet?, where is the battery?.Hope you can help.
Cole@MBS
www.mbssouthampton.co.uk
Battery in the boot Pete under the trims, good night for forum members breaking down!!!!!!!
peterwhayward
peterwhayward
grays essex
Thanks for quick response Cole....heres hoping the key operates the boot.
peterwhayward
peterwhayward
grays essex
If the worse happens and the blade key doesnt operate the lock is there access to anything under the bonnet that would allow sufficient charge to be given so the boot could be openned by the button inside the car?.
Cole@MBS
Yes, main feed to the front SAM, but, best bet is the main feed on the starter if someone wants to jack it up and slide under there....
peterwhayward
peterwhayward
grays essex
thanks again Cole.Its nice to be armed with some info for when the RAC finally arrive.You never know who will turn up and what they know.
What! :shock: No jump start posts under the bonnet? :shock:
Some cars have them again, but for years many did not have any real jumping point, the S class and the CL now have a real one, the 230 does not
Do not forget on the 219.3 they have 2 batteries, with a battery problem the consumers off message should have come up with many things turned off, when the batteries are low you will find the idle is higher than normal.
You must always disconnect the main one before the aux.
EmilysDad
Bury Lancs
ML350
I know where my battery is (I read the ****ing manual ;)) ...... bu66ered if I know how it comes out though. :rolleyes: :rolleyes:
BAZZER1
FERNDOWN DORSET
E320cdi AVANTGARDE SELECT
That comment was a bit uncalled for I am sure Malcolm as always was trying to help you in the best possible way
Im sure it was only mean in the RTFM type way, and not in a malicious way towards Malc's post. :D
Your car is not a 219,it was for peter
EmilysDad
Bury Lancs
ML350
Woah! It was a tongue in cheek comment re my car ...... not Malcolm help to the OP. ;);)
Sorry for the confusion! :Oops::Oops:
BAZZER1
FERNDOWN DORSET
I'm sure it was not meant in a bad way as Malcolm is always very helpful to all Forum Members
Tel: 020 8863 9233
