Flat battery recharged - now key won't turn?
Essex, England
200CLK 1997 2.0 Auto Sport
Hi there, new here, and been encouraged to post a new thread on this by a Senior Member. My lovely 200CLK (2.0 CLK auto Sport 1997) came from a lady friend who was upgrading just before lock down and so I took the car off her hands as a spare car during Covid - we are on the list so shielding and the car hasn't moved beyond moving it around on the drive since then. Looking in I realise we should have been charging it regularly, but I haven't as it seemed to be keeping quite happy and starting immediately all the time. Over the past week I have been trying to get her going again and she was lighting up, but not turning over so I got the charger out. (thanks by the way to other forums here - the boot lid was stuck but I got that sorted and have come back with another problem but haven't been able to find a similar answer).
So I've charged overnight and the charger says the battery is full. BUT, now the key which definitely was working before goes into the ignition and it's all locked up, nothing lights up, and I can't even turn the key? What can possibly be going on? Any clues much appreciated - I am missing the manual as well - though ordered it's a week away from arriving. All help much appreciated as I have insured and taxed her now and keen to get her running again. - Thank you in advance!
Craiglxviii
Cambs UK
Firstly, hello and welcome!
where do you live? We may be able to help suggest a repair solution.
Secondly, have you checked the battery with a multimeter?
Can you open the bonnet?
What happens if you try to turn the key (only to position 1!) while the battery is still on charge?
Do you have an OBD2 code reader?
malcolm E53 AMG
First couple things to try are replace the key battery and check the existing car battery it should be 12.6V fully charged. If it’s an old battery I would change it anyway MBs don’t like undercurrent batteries (it may not be holding charge) it leads to all sorts of spurious electrical issues.
Craiglxviii
Cambs UK
The key should still work in the ignition lock even with no battery at all, the EIS has an induction coil to power the transponder when the key is inserted.
Unless the EIS has no power...!
Mechanicalincentives
Essex, England
Thank you so much - and super pleased to have such a flurry of responses - it's brilliant to find such a source of knowledge.
To answer your questions
We are about 10 miles east of Stansted Airport.
Yes the bonnet opens
There is no movement at all on the key.
And I don't have an OBD but have been meaning to get a cheap one. I'll look up for recommendations and get one - any suggestions welcome
Craiglxviii
Cambs UK
ICarsoft i980 is the basic one. Assuming your car has OBD2 and not 38 pin diagnostic (rectangular not round)
Id be looking to get the car recovered to an Independent garage if you have ignition lock problems.
Essex, England
OK, so I have charge in the battery but no sign of life whatsoever, and have tried a) Steering lock challenge, and b) battery change I haven't got the right battery in my stores. As it seems it should work even if flat I am going to call in the RAC as I have home start and I do have an independent garage I use if needed. I'll keep updated. Thank you so much for the flurry of suggestions.
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Hi there, new here... So I've charged overnight and the charger says the battery is full...
Can you provide any further details of your battery charger such as;
  1. Make and model No?
  2. Programme of charge selected for the overnight charge?
  3. Where (To what) did you connect your charger leads?
  4. Was the battery still connected to your car during the overnight charge?
onefortheroad
uk.
same issue what happened...my doors will open and lock so battery not completely dead....but key won't turn ?
can you get ignition lights ?
Reginald
Cheltenham
www.prestigecarfinance.com
320 CDI CLK Coupe W209
Hi no ignition lights as key won't turn at all...however, the lights come on and the main lights work so the battery doesn't appear flat ??
joderest
ML270 2003
have to ask, have you tried putting key in ignition, then turning steering wheel slightly, then try turning key ?
It may well be the steering lock is a bit jammed.
joderest
ML270 2003
also, is gear lever in park ?, may be the solenoid has got confused, try disconnecting battery, leaving for 30 mins and reconnecting, make sure lever is in park.
Reginald
Cheltenham
Hi Guys
The key is dead as far as turning is concerned...wont turn at all...
I will disconnect battery for 30 mins tomorrow and see if that works and double-check car is in park...its hardly been used for the last few weeks and is very cold !!
Charles
Frontstep
T210 320cdi
Methinks you haven't got a full complement of volts yet .
The RAC should be able to assist you with that as the season for battery issues gets underway they will be equipped oh and probably try and flog you a new battery!
Or test it yourself.
Reginald
Cheltenham
Thanks chaps ...it’s a plastic square key and from memory it normally clicks in and lights the ignition...have tried moving shell but no go....if I test the battery what voltage amp age should it show ....the headlights work on full beam so doubt the voltage is down ?
