Fluctuating Brakes
Joe0675
BIRMINGHAM
2005 C220 CDI Elegance SE
I recently bought my first Mercedes - 2005 W203 220 CDI Elegance - great car quite a few miles (120k) but very pleased with it.
On the last MOT there is an advisory for both front brakes which reads "front brake fluctuating but not excessively". I really have no idea what this means, can anyone help me please.
I do notice sometimes under moderate braking there is a slight throbbing through the pedal as if the ABS is pumping a bit.
The brakes are not as firm as I would like but a visual of the pads and discs looks fine. I'll give them a good bleed through and change the fluid when the weather improves a bit!
Any ideas?
I think this means warped or out of true front disc, the will give an increased pedal movement as the disc will push the pad slightly further back than it should do, its slight, but ii could have a little effect as well as the bumping that you feel through the pedal.
.... but a visual of the pads and discs looks fine. .....
They looked OK (apart from a wear ridge) from the front on my Vauxhall, but when removed you can see they weren't. ( the rear of a disc is difficult to see due to the stone guard )
front/outer
rear/inner
As above you cannot see the inside and you cannot see anything if out of true
Joe0675
Joe0675
BIRMINGHAM
Thanks for the advice. I'll have a closer look and think about replacing them. Any advice on replacement discs?
Check with ECP and get a Forum discount
Joe0675
Joe0675
BIRMINGHAM
Got a set of Pagid discs from ECP for less than £50 and put them on - problem of 'fluctuating brakes' now solved. Braking is much much better than before, good and solid and no more vibration.
Very pleased!
