Fuel Filter Change
offroader
Cheltenham, Glos.
M-Class/2000/V8,4300cc
I have a W reg. ML430 and am just about to change the fuel filter. MB describe a tool for removing the pipe couplings from the filter. It has part number 163 589 00 37 00 and looks like a pair of very long nosed pliers with the ends of the jaws bent in.
Do I need this?
On my other car, a Volvo, the couplings can be removed by easing an open ended spanner in between the filter and the coupling but I don't think this is the same.
Is this tool unique to MB or is it generally in use?
Any advice would be appreciated.
Offroader
LYNALL
Kent
I just popped the end of the clips of with a small screwdriver and used a pair of sidecutters to refit easy if messy job even with the hose clamped off, this was on a e430 not sure if same set up, clips shouldnt have rusted as they are stainless steel.
Google r clip.
Lynall
