Fuel problem - Engine dies with 1/4 tank
Status
Not open for further replies.
Arnie
London
Have a problem on a1991 G-wagen with a 300E petrol engine.
The car seems to run out of fuel before the tank is empty. (90 litre tank, Engine starts dieing when down to about 1/4 reading on gauge and it takes only 60 litres to re-fill tank.)
It had a new petrol pump fitted before purchase and since then the level sender unit has also been replaced.
Could it be that the Fuel feed and return lines on the tank are swapped around? Any ideas anyone?
sunil sood
Fuel problem
did it have a new fuel filter as well?
if not, could be blocked?
white190
Ipswich / UK
hobbystage.net
Fuel problem
RE - Could it be that the Fuel feed and return lines on the tank are swapped around? Any ideas anyone?
you could be on to something there I have known that to happen ...
altreed
Dorset, UK
Fuel problem
I had a similar problem on my golf Gti, it turned out to be the fuel pump priming pump.  I had to replace the pump that picks up the fuel and primes the main fuel pump.  £30 later, sorted!!!
The device was where the fuel pickup pipe went into the top of the fuel tank, I unbolted it and replaced the little priming pump.
A
Arnie
London
Fuel problem
Thanks,
looks like I'll have to investigate the fuel pumps and see exactly what has been replaced and how.
The pumps are under the rear wheel arch, outside the tank, so should be straightforward... I guess.
(Edited by Arnie at 6:16 pm on June 20, 2002)
Status
