gaining entry!
craigufo
AUSTRALIA BRISBANE QUEENSLAND.
W124 300CE 1989 & R129 500SL 1990
Hi all!...wondering is there anyone here with knowledge or has been in the following situation??..i have an 1989 w124 300ce "coupe" battery is flat with hood & all doors & boot locked no response from door locks when key is inserted & turned:confused: thanks in advance all ;)
Corned
East Midlands
2005 S211 E320CDI Avantgarde
These should do it. :)
Alternatively, use the search facility on here as there are several threads over the years on how to power up the car again in this situation.
You need to raise the car and get 12 volt on the large wire on the starter motor, the remote will then work
rpe2
Silchester
Being of a 1989 vintage, I don't see why sticking the key in the lock and turning it won't allow access..
The locks seize up when they are never used
Xtractorfan
S class
Not sure if a number plate lamp will allow you to connect a charger to put some charge into the battery ..remove the light and connect to the wires..
He cant get in to turn the lamps on
rpe2
Silchester
No, but one may be able to access the wires from the outside.
A bit of lubricant in the lock?
I do not follow Richard, what wires are on the outside
rpe2
Silchester
I'm pretty sure that 12v has been applied via the numberplate light wires in order to get a little current into the car worth some success in the past.
Devonian
I don't see how that would work unless the Lights were still switched on
C
craigufo
Thanks for all the replies guys! i got access through raising the car & power to starter! cheers! & thanks again television. ;)
Please do start spraying some PTFE into the door locks and soon the key should turn.
