gear box
darren007
i have had a e300td for about a month now and have noticed that after doing 130-135 mph the car willwill not change up the gears even at low speeds is this right a sort of saftey thing or is something wrong? it wiil change up a gear only when tou reach 4000 rpm, thanx for advice.
darren
SLinKyjoe
Does your car change up normal after you have left it for a while?
turnipsock
Port of Menteith
c'mon guys, I got the same sort of comments when I complained about wind noise at 130mph on B roads in the wet.
Does the problem persisit for long or does the car go back to normal quickly?
SLinKyjoe
I was really enquireing if the car goes back to normal after being stopped and switched off, then it will be the logic in the throttle/gearbox system that is expecting to be driven. the ECU brain learns the driving style and will adjust the upchange to suit the input. if you drive a car at 130mph it will be using some throttle to do this and the older versions of this trickery stuff will not update as quick as the latest generation. so it will need to be reset by knocking it off. it re-learns the new inputs when driven again. this would explain the situation described above if he means when driving slowy the gears dont change up till late in the rev range. for those cars with throttle by wire and tip fucntion gearboxs you can instantly influenece early upchanging again by light throttle inputs and serveral taps on the gear selector at low revs in the + direction. a few of these and the car will start to upchange again early.
tom7035
Darren007 (? :)) surely wouldn't want this to happen on the racetrack though, so I don't really understand his complaint. I certainly hope to Christ he's not referring to its use on the public roads!
paulcallender
Banned
NW
It sounds like low or bad fluid - it sounds like the transmission fluid is overheating. Which model is it and which version of gearbox? I am guessing W210 and 4 speed box here. Or if its the 5 speed, which is electronic, then Slinky's suggestion of a 'reboot' would be a useful diagnostic, since its shift points are managed electronically, not hydraulically.
D
darren007
thanx for advice, i went to check fluid but no dip stick? does anyone know if one from a c250 diesel would give me the correct reading? it does go back to normal after being left for about an hour!thanx again for the advice.
www.W140.co.uk&www.r129.co
