gear stick gaitor how do i replace this?
paul vp uk
dualinern04c class elegance 1997
Bought a new gaitor cover 4 my 04 vito , the old one was tatty.
is there any advice on how to replace said item without breaking the trim.
regards Paul vp .
trying to smarten up my dualliner :):)
I do not know the Vito well but on the cars the gear shift cover / Gaitor just prises out and held with spring clips on the four corners.
With the VIN number I may be able to give an exact answer
Quick Silver
Moonshine Island, surrounded by water
R129 1990 SL 300..
regards Paul vp .
Just prise out round the edges, lift skirt over knob, undo and remove knob you can now remove old gaitor and replace new one . A 10 min job. There are two types fitted to 638 Vitos very early ones did not have a leather gaitor.
paul vp uk
paul vp uk
Got the cover off but unable to remove the gear knob it appears to be attached to the linkage ie reverse ( lift ) gear.
so still struggleing.
what happen to just unscrewing the gear knob , old days
Is there a collet on the underside end, if so you just turn this one 1/4 turn anti clock and it pulls off
paul vp uk
paul vp uk
HAD A LOOK and found it
many THANKS .Malcolm
Regards Paul vp Gloucester
