Gearbox problem e300 hybrid
Thejeweller
E300 bluetec hybrid 2013 7g
Hi I am experiencing problem with my 7g auto gearbox, but because it is a hybrid model not getting very far in having repaired. When stationary and try to pull away it sometimes becomes jerky and little power, also when asking for power when going can also do the same.
Does anybody know somebody who may be able to repair.
Main dealer said needs new gearbox!
Cheers
Frontstep
T210 320cdi
The usual cheery diagnosis from an agent who doesn't want to see the car.
Certainly some on here have had them, it sounds a casual diagnosis.
Do you have a MB "Star" diagnosis report for those on here who know better than me about them ?
Welcome, where are you located then we can advise someone
T
Thejeweller
Cheers
Cheers
Cheers
Cheers
T
Thejeweller
Hi I’m based in Dover, Kent.
Had star report.
Main faults include P073100 gear 1 implausible
P073000 impermissible transmission ratio
P072900 gear 6 implausible
P087000 oil pressure switch C has electrical fault
P170900 y3/8 cannot be reached
P171200 y3/8n4 is defective
P073200 gear 2 implausible
P073500 gear 5 is implausible
Amongst others
Sounds like a valve body or gearbox electrics fault. It can most probably be fixed without replacing the whole gearbox :)
If that was a 5G I'd say conductor plate....
Gearbox electrics are essentially the same thing on the 7g, as the TCU and the conductor plate is now one unit.
As is the Hybrid motor on this one...:shock:
Well, the Torque converter has been replaced with an electric motor. I don't see that reparing this box would be any different to repairing one from a non hybrid vehicle.
'twas tongue in cheek Alex, I'd agree but suspect the MB main dealers wouldn't :rolleyes:
menukawow
E300
Anyone know the issue on this? Should i repair? Car is working fine no issues. Please check attached
ignore
Bad auxiliary battery is most likely, those will lead you up a garden path
Peter Goh
E300 Hybrid MY2014
Cheers
I just joined as a member to this forum and I read your post which is very similar to my current issues. Since yours was over a year ago, I was wondering if u did manage to get the problem resolved. If so, would you mind sharing how you overcame the problems. Cheers! Peter
www.ckinsurance.co.uk
