Gearbox problem
wolfie69
This year i became a proud owner of a M reg 250d automatic
Last Monday it sailed though am MOT with 211 thousand miles on the clock
It also got a service while it was there
On Wednesday it started going wrong
When i was driving it start to jump at about 3000rpm, now when I engage drive or reverse nothing happens until I press the accelerater at about 2500rpm it starts to move it also lost fluid yesterday as well. could the garage have done anything wrong
has any body got any ideas what it could be and what it would cost to put right
kebo57
Lanc's
ml270
250d Auto box M reg
wolfie69 said:
it also lost fluid yesterday as well. could the garage have done anything wrong has any body got any ideas what it could be and what it would cost to put right
When you say it lost fluid yesterday, do you no were it came from, what sort of oil it was & how much it lost.
Parrot of Doom
Manchester
Try starting the engine, putting the parking brake on, and moving the gearbox through all gears backwards and forwards, for about 2 minutes - idle speeds only.
Just thinking if they've changed the gearbox fluid, it may not have worked its way fully around the system.
Chances are though its low, as slipping is a classic sign of low ATF.
W
wolfie69
__________________
I am not quite sure but there was a nice rainbow colours on my drive yesterday it was probably a couple of liters it also used quite a lot of diesel
Cheers Wolfie
W
wolfie69
What does this ATF mean sorry i have no idea about cars
cheers Wolfie
cheers Wolfie
ATF is automatic transmission fluid, you said in your first post that you were leaking fluid, could this have come from the box.
malcolm
W
wolfie69
I would like to thank everybody for there help
Wolfie
Hibbo
East Scotchland
It definately sounds like your gearbox is low on Automatic Transmission Fluid. DON'T drive it like this as you will quickly knacker your box!
A pipe went on my 300D to the transmission oil cooler (under the radiator) and it lost ATF. Should be a simple fix, but don't risk damaging your box.
W
wolfie69
Got it fixed today 120 pounds it was probably the same pipe
Thanks everybody for your help
W
wolfie69
Hibbo said:
Nice one mate, now go and put another 200,000 on it!
I hope so
I saw a mercedes on ebay last year with 800000 on the clock
