Gearhead for diesels
Ritchie Moore
New Registration
1997 98 300d
Hello all,
I would like to thank everyone in advance for letting me join the group. I'm a proud owner of 1997 300d wagon and c class car here in the USA. I'm advocate of diesel engines from a young age with a lot of knowledge from multiple turbocharge engines. I've join the forum cause I to want to hot rod my m606. I've done some research but obviously I seek more info. The n/a m606 I have is already under going my knowledge of changing it's characteristic for more air I've already ported and polished the head install harder seats and up the seat pressure on the intake valves to 300 lbs. I have ready to install a 12mm injection pump that I'll probably start out at 450 cc of fuel I've upgrade the injectors mostly opening the sack in the tip but not changing the nozzle projection. I'm wanting to stay with the n/a (that I have already had harden) I will be building a tuned header along with a force enducted intake. I'm not wanting crazy boost I just wanna flow a lot of air will my rods handle it? and my turbo of choice would be a mx82 holder. Am I asking for scatter metal here?
A.J.
Norwich. UK
Hi Ritchie, welcome to the forum :)
Craiglxviii
Cambs UK
Hi Richie and welcome. I wish I understood anything of what you said but good luck to you!
carlls
grimsby
2005 cls350 gone 2009 320cdi sports estate
hi and welcome completely lost me with but wish you luck with your project
Hi and welcome. Why increase the valve spring force unless you plan to rev it higher in which case why not do exhausts as well?
I also don't get why you'd fit tuned headers and a turbo? The turbo will negate all the point of tuned exhaust headers.
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome Ritchie, if you want a higher revving engine ....there are petrol variants ;)
Craiglxviii
Cambs UK
Rule of Cool ;)
turbopete
Spennymoor
2018 '18' Ford Edge tdci biturbo (sorry)
IIRC someone on here recently tried to add a turbo to a N/A OM606 and ended up bending the conrods. they are different in the factory turbo'd OM606 than the N/A version so id say you will experience the same issue (or its highly likely)
Yep I recall something similar.
