LNM
Got a rather bad case of Hellmans in my coolant system. Suspecting the worst in the form of burst head gasket as the root cause; but if it is its a very gradual burst because I've driven it for months without noticing a problem. I discovered it by fixing the level switch which was trying to float in the stuff + predictably enough, was having difficulty doing so.
Has anyone ever gotten rid of the mayonnaise caused by oil in the coolant using automatic detergent to break down the stuff? The head gasket has gone before + was replaced by MB; possibility that this stuff has been in there for years, or
the gasket has gone again.
There is also a coolant leak from under the car, directly under the heater matrix (this leaked when cold the other day when I filled up the coolant again) Can't really see how these would be related, but thought I'd mention it, your honour.
