Getting to grips with the COMAND APS
bacoms
Near Winchester
2005 E320 (W211) CDi Elegance Estate Tip, 2000 E320 (W210) CDi Elegance Estate Tip (sold)
Hi folks,
Having had my new 2005 E320 CDI for just over a week now, I am beginning to develope the opinion that the COMAND APS (DVD version) that's installed either isn't up to much or I just haven't figured out how to use it properly.
I already discovered that it will sort of sync. with my Bluetooth phone but will only load into its memory the first number found per contact. The others are ignored. This is despite it supporting the direct input of a mobile, a company and a personal number per contact.
The SatNav features seem fairly limited. It doesn't have anything like the features, the ease-of-use or the depth of information that may be found on a sub £100 portable satnav that sits on the dash. (Perhaps 4 years ago when the car was manufactured, it was state-of-the-art compared with what was around then.)
The thing that really gripes me however is so basic that I can't believe it's not possible. I've switched on the COMAND, selected Audio, then Radio. I can now control the radio completely from the steering-wheel so why do I have to put up with that bl**dy distracting screen in the corner of my eye when I'm driving?
Is there a way that I haven't discovered yet of having the screen go to sleep after a period of inactivity until I want to next use COMAND?
I can turn the screen of on the earlier version and I am sure that you can do the same on the APS version
B
bacoms
Near Winchester
I feel sure it must be possible but I just can't figure out how to do it. It isn't obvious to me. I've been through the manual, tried all the setting and still the screen stays on.
How do you do it on your version?
Mine is the earlier version, and I have a button that dims the display and turns it off.
Someone with one should see this post and be able to help
whitenemesis
CLS55 AMG '05
Not possible to turn the screen off on the COMAND-APS as fitted to the C class. This is something I to would love to be able to do!
Thanks Peter,,I was wishing that you were on line:D
B
bacoms
Near Winchester
Looks like it's a feature then. I find it damn annoying and totally unnecessary but it looks like I'll just have to get used to it. Another point against the COMAND APS as fitted to this model.
whitenemesis
CLS55 AMG '05
My experience is with the unit as fitted in the C class but I would imagine it will be the same in your E
I don't find it distracting as such but am concerned it could lead to premature failure of the display...
B
bacoms
Near Winchester
Good point. Anyone know what the life of one of these displays is?
Thats a hard question, they are back lit, even if you turn it off, the other components are still running
whitenemesis
CLS55 AMG '05
True but I have already noticed "image burn" so I tend to switch to Map view. At least the image is constantly moving...
Good point Peter,,I have to run mine at max brightness as when the top is down you cannot see mine, I will start turning mine off now on thinking about it
Tel: 020 8863 9233
