Glow plug fault, E350 saloon 2010
KellyMK
2010-E350 blutec saloon/W212
I have an intermittent fault, and on start up the car splutters until throttle is added, local garage said it might be a glow plug issue? appreciate any pointers
onefortheroad
uk.
Cycle the ign on and off 3 times . Wait 10 seconds between each cycle . See if things improve.
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
Read your fault codes, without doing this step it's purely guess work
glow plug light would come on and stay on for longer if a fault with GP circuit (plug or relay. Change all the plugs at the same time..
local garage is guessing, needs to go on diags.
Spluttering could be a million and one things, blocked fuel filter, manifold leak, boost leak, no fuel, so on and so forth
K
KellyMK
Thanks, its having a diagnostics test tomorrow morning, will see what that shows
malcolm E53 AMG
Interesting to see what diagnostics show possibilities are a glow plug relay or one or two glow plugs failing. The earlier OM642 was noted for burning through relays <100k miles not so much the later >2009 engines - you don’t mention the mileage the car has done which is always a factor?
This shows the relay module replacement procedure:
Glow plug replacement:
onefortheroad
uk.
Did you try my advice ?? These engines are prone to leaking fuel back to tank overnight. Cycling the ign primes fuel pressure to the max ,ready for a start .
K
KellyMK
Thanks for this information, car has done 157k/miles.
K
KellyMK
Not yet, it wouldnt start this morning, tried 3 times to do so, it eventually kicked in but was making a lot of strange noises. Diagnostics being done tomorrow, Thanks
