GUIDE: Replacing your fuel filter (W208)
JSeaman
Derbyshire
C220 CDI 2005
Step 1 - Jack up the rear offside nice and high so you have room to work (don't make the job harder by cramming yourself in a tiny gap).
Secure the car with axle stands
(not shown in this photo sorry)
Step 2 - Locate the plastic cover over the fuel pump, this i just in front of the suspension as shown
JSeaman
Derbyshire
C220 CDI 2005
  • #2
Step 3 - There are three plastic 10mm nuts that hold the plastic undertray on, you will need a couple of extension bars on your ratchet to reach them through
the holes cut out in the plastic cover as shown
Step 4 - Remove the 3 nuts then wriggle the plastic undertray out. It is quite squashy so easy enough to move around but it is a little awkward - don't just
tug it because you could damage pipework
JSeaman
Derbyshire
C220 CDI 2005
Step 5 - You will now see two metal cylinders, one is the fuel pump (the smaller one) and the other is your fuel filter. I have circled both on the picture
Step 6 - Hopefully your filter carrier will be in better shape than mine, if so then release the carrier so you can access the filter
Step 7 - Now onto the pipework, you have 4 connections to deal with, the first is easy just pull it off
JSeaman
Derbyshire
C220 CDI 2005
Step 8 - Next is the output line which runs to the fuel rail, this one will leak quite a bit of fuel so have a vessel ready to catch it. When you release the
jubilee clip it will start leaking so get some goggles on and make sure you're not right under it!
Step 9 - Next is the link between the filter and fuel pump, again, this one isn't too bad and won't leak loads so you can take it off and replace the pipe if
it is in bad shape. It's worth inspecting the hoses if you can as there are often defects you can't see on the car, I highlighted one of mine in the second
JSeaman
Derbyshire
C220 CDI 2005
Step 10 - Be prepared to fit an array of new jubilee clips as required! They get very tired under the car and you are likely to need to replace some of them
Step 11 - Finally, there is the main feed line which will leak a lot of fuel. The way I did this was to switch over each pipe one at a time to the new filter
, finishing with this one. If you try and disconnect all 4 then change it over you'll spill a lot of petrol!
Step 12 - Reattach your pump, I had to do it with a cable tie!
JSeaman
Derbyshire
C220 CDI 2005
Step 13 - Once everything is back together, fire up the car and check for leaks
Step 14 - Now slide the cover bak up (two bolt holes are nearest the wheel and the single bolt hole nearest the centre of the car). Be careful not to hook on
any of the wires. One thing I forgot to mention, check all the rubber mounts are hooked up (I circled two of them on the second picture) before you cover it
up
Step 15 - Tighten up the 3 plastic 10mm nuts and drop the car down off the jack
Uncle Benz
West Sussex
Mainly Mercedes
Nice write up!
Always use an axle stand or two if venturing under a car. A trolley jack is not sufficient on it's own.
Play safe out there guys!
Nice write up!
From another aspect I was working under a MK10 whilst on a trolley jack, I came out to get some tools and my 2 year old came out and let the jack down, it makes you think
JSeaman
Derbyshire
C220 CDI 2005
Yup, as per step 1 - use an axle stand
I've seen more than a few jack incidents occur now so look after yourself
grober
Scotland
W204 C200cdi estate
Excellent write up. However I would take issue with a couple of things. Holding up a component on a high pressure fuel line with a nylon tie is simply not good practice. Especially if the component in question A2024711341 BRACKET http://www.neoriginal.ru/cat/mb/part__1_1_45Y_208_465_/47_030
is a mere £10-31 from Inschape probably less than the cost of the filter! You will also reduce the spillage of inflamable fuel by the use of proper fuel line clamps e.g. these are very neat and will fit into confined spaces http://www.sealey.co.uk/PLPageBuild...rogroup=1238&analysiscode=&requiredresults=16 and cost a mere £13-50 Their rounded jaws are better than using vice grips which is probably how the flexibles were damaged in the first place.
JSeaman
Derbyshire
C220 CDI 2005
Grober, thanks for the feedback it's all welcomed.
To be clear, I wasn't recommending you ditch the cage and go for a cable tie - my sarcasm obviously didn't come across! That said, if you find yourself in the situation I was in then you can easily cable tie it back up (temporarily) as the fuel pressure does not move the filter around.
I'm not a fan of clamping the lines, the way I did the filter you just switch one line at a time and never clamp them but interesting clamps though, I hadn't seen them before
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
i love guides like this, good work documenting, you should do more
but !!!!!!!!!
next time show photos WITH car stands, i've seen cars on jacks that have 'fallen' down or lost pressure and come this close to damaging someones head...
i hope you don't mind but i've edited your post to spell it out loud and clear
cheers
niall
JSeaman
Derbyshire
C220 CDI 2005
I hope there aren't too many more, they just grow as the wife's car needs attention! :)
There were already comments in there about axle stands, I move mine around so they are right next to me when working on the car so they appear absent from the pics but they are in constant use (2 usually), no problem if you have/want to add more comments about it though
jefrs
Berkshire
S210 98 E320 Estate Av petrol full load
Cable ties - rarely known to fail and cost less than a penny each. I might have slapped two in there to prevent it wobbling. New bracket? - great but you haven't got one when you're under the car. Cable ties then.
It may be a "temporary" but you won't get a round tuit to go digging under there again just to change a cable tie.
Slightly OT - I'm a little surprised by the amount of rust on a few of the components lurking under there. Might have taken the opportunity to splash some Waxoyl about. I know it's not the best stuff but it does come in a handy squirt can.
JSeaman
Derbyshire
C220 CDI 2005
jefrs, you know how long 'temporary' fixes last :)
It's a very rusty underside, that's true of most of the car. It looks immaculate on top but underneath there is plenty of tin worm lurking sadly
JSeaman
Derbyshire
C220 CDI 2005
  • #17
:) That could get expensive! There are a number of different rust treatments out there, nail polish would not be high up my list
wroudy
New Registration
NY,NY
C280 1998 W202
HI, I cannot see the pictures.
JSeaman
Derbyshire
C220 CDI 2005
  • #19
I'm afraid I have reached my limit for usage so they will be back on the 8th
