Yes, it was attached, I was retightening the hose and seals and found this.Was the hose attached to it? If so it’s blocked, poss rad weld??
Have you tried poking a screw driver in there? It looks like it's part of the cooling system so it shouldn't be there. What's the rest of the system like?
Easy way to prevent stuff going in is to make an initial hole then put the hose into the disconnected rubber pipe. Then as you poke away at it the pressure and water in the system will flush the pieces the correct way out of the system.If you do start stabbing at it with a screw driver, its will be difficult to prevent bits falling inside, can you unscrew the metal housing and clean it on the bench.
Is that a recently aquired car. Why would you need to tighten the clamps on the hose.
Driving a car with such a blockage on the cooling circuit is asking so for serious damage -assuming its a coolant pipe, which I assume.
As mentioned where does the other end of the pipe go - is it cooling circiut.
As mentioned above it could be radweld, but surely rad weld wouldnt block such a huge pipe.
Can you find the part no stamped on the part and google it too how it should look or take a trip to your dealers and get a replacement part. It looks like tois part of the engine actually from the pic.
Whatever it is it needs sorting, last thing you want is that rust weakening the metal if it hasnt done already, then a good flush and refill with coolant.
I will be interested as to how you progress -good luck
Anyway, the other end of the blocked pipe is my cooling circuit, it goes up to the heater hose, and my heater isnt working (I turn it on no hot air comes out) ....
I believe my car doesnt have it.I think you just found out why your heater isn't working.
Does your car have an LPG conversion perhaps? That can require rejigging the heater circuit but I can't see why that would require the pump outlet to be blocked.
What do u mean?Wet carpet
