Hard start problems on a federal model '77 280e
troylatif
Hi all,
I acquired not too long ago a 1977 280e with m110 engine (L6 w/ DOHC) vin 123.033. It badly needed a rebuild. So I rebuilt it with new piston rings and valve seals, etc. As far as I can remember, the car only had problems with holding cylinder pressure.
After the rebuild, I'm having a hard time getting the engine to run smooth or start at all. The problem I'm seeing is that there's an ignition problem again or there's a serious compression problem on one or more of the six pistons causing it to basically run on 5/6 or less pistons.
This sort of confuses me because I took my time on the rebuild and sat the rings 180 degrees opposite to one another and had the block rehoned of course. The only thing I can suspect is that I have a bent valve causing a cylinder to not shut completely. I suppose I should probably video tape the car trying to start and let you guys hear it for yourselves, but anyways.
When I was timing the engine back when it was on stands I was turning the crank to bring it into sync with the cams and I might have bumped a valve with a piston although it was by hand on the crank bolt. Could that have bent a valve enough to cause a serious leak?
Your feedback is appreciated,
-Troy
Xtractorfan
S class
Have you checked all the cylinders for compression, I get a suspicion that u may have mistimed the engine. go back to the start and check everything thru, make sure the spark is happening when both valves are fully closed. it is very easy to be half a turn out on the timing and not realise it
