Has anyone used Mannol Defender Oil
John77
E200 Estate 2011, 2009 SLK 200
My hobby is buying broken Ride on mowers, fixing, servicing and selling. I am always looking for cheap oil to use in them.
Anyway I have seen Mannol defender oil for this, but see that it has a MB 299.1 Manufacturers Approval and wondered how good it would be in a Mercedes. Has anyone used this? My cars are all Petrol, Automatics with M271 Engines.
MANNOL Defender 10W-40 API SL
Corresponds with requirements / specifications / products:
SAE 10W-40
API SL
ACEA A3/B3
MB 229.1
VW 501.01/505.00
Mannol Defender 10W40 is a multipurpose multigrade semi-synthetic engine oil with hydro synthetic base for modern gasoline and diesel engines with and without turbocharge. It is produced with the use of unique StahlSynt wear-out reducing technology. It provides high degree of protection for new cars as well as for cars with big mileage. Prolongs periods between oil change. Mannol Defender provides safe engine combustion at high loads and frequent temperature changes.
Product Characteristics:
Characteristics Method Unit Value
Density at 15°C D 1298 kg/m³ 868
Flash point COC D 92 °C 224
Pour point D 97 °C -42
SAE-class 10W-40
TBN D 2896 gKOH/kg 9,2
Viscosity at -25°C D 5293 CP 6276
Viscosity at 100°C D 445 CSt 14,07
Viscosity at 40°C D 445 CSt 95,34
Viscosity index D 2270 151
Pretty sure it's the wrong MB spec for an M271.
229.5 or 229.51 is the correct spec.
mioba
Nottingham and Köln
MB 229.1, thats an OLD spec.
I cant think of many mercs on the road using that and it is semi syn.
mioba
Nottingham and Köln
my w124 is MB229,3, had only mobil 1 in it since day one
You'll probably find in the owners manual that 229.1 is also suitable for your 124.
I’ve got two barrels of 20L Mannol oil in the garage . One in 229.5 for the CLK and the other 229.51 for the E class .
They were so cheap on eBay I couldn’t not buy them
John77
Thank you. What are they called, if you remeber?
Is this oil spec, 229.5 petrol and 229.51 diesel Alistair?
Yes but 229.51 can also be used in petrol.
229.51 has a different additive pack which makes it DPF friendly and also higher detergent level to hold diesel combustion byproducts in suspension.
00slk
Cambridgeshire UK
Thanks Alistair that's handy to know ;)
