head gasket
simon tompkins
hi guys just a further querie if i did have to replace the headgasket on my e280
p reg roughly how much should i expect to pay
It is a days work to do it
Uncle Benz
West Sussex
Mainly Mercedes
Is that a straight six or a vee?? Personally I would struggle to do a straight six in a day, usually booking the car in for at least two. This takes account of the fact that I will always get the head skimmed to true, and my local friendly machine shop don't know the meaning of the phrase "hurry up!". I can't complain as their job is always of top quality!!
Vee six obviously has two heads, so unless you plan on just doing one, it is even more work!!
simon tompkins
its a straight six,im not saying i need it done but i have got a water leak which is getting quite bad,its on the side of the water pump and im hoping its just that,so what would i be looking at cost wise for a head gasket roughly?
thanks simon
Uncle Benz
West Sussex
Mainly Mercedes
£700 - £800 at an independent, using genuine parts and new head bolts.
Quite likely to be an issue with the water pump, IMO
simon tompkins
thanks for that mate i do think its the water pump i will try that first as its the cheapest option and quick to do.
thanks simon
mikestrivens
Stockport
I have just had my 320TE done - 10 hours plus head skim, head bolts, and head set.
kth286
E320 Coupe 95
I think you will find a water pump change on the 104 engine is something like 6 hours shop time plus cost of pump (approx £200 genuine) so not cheap BUT will last another 14 years if done properly and proper Mercedes coolant used.
After a run any water pump leak could be found by feeling under the pump at the front, they all go at some point in life, mine failed at 20k miles
