headlamps clouded over with age
iainpatton
Worcestershire
E300 1998 TDI
Hello, my 1998 E300 has got clouded front light lenses and I can drive around on full beam now and noone complains! Looks like the plastic has aged badly. Can I get new lenses or are any newer lights compatable? Thanks. Iain
Frontstep
T210 320cdi
Try 1200 W&Dry then T-Cut,
or I have no doubt some one will suggest "Wallet polish" available in tiny bottles at ludicrous prices.
It doesn't polish much except the vendors wallet.
JEZ.S320L
Costa Calida, Spain
www.latorreonline.es
sfc501
Maguiars Plast-RX Plastic Polish, Apply & Machine Buff off.
Wet/Dry process is ok but as you'll be taking off a layer from the headlights you'll have to do this process regularly.
JEZ.S320L
Costa Calida, Spain
Having cleared the lenses, would X-Rain (or similar) not protect - or seal - the treated lenses, thus avoiding repeating the process regularly?
It has been done with great success with 1200 to 1500 paper and a plastic polish like,the above. Mothers polish is very good
Burgmeister
Torbay
E300TD 1998
Nope just polish them when you polish the car, there is nothing else that can be applied
M
Monky
Our valeter uses some sort of autosmart compound and machine polishes them, always works a treat and they look brand new. I quite often buy Porsche 996's and the older lights seem to suffer quite badly from this but after 20 mins they look good again.
scotty2hotty81
1200 1500 machine polishing machine with meguires scratch x or find a decent detailer and they should be able to do it at a not to expensive price
william28ho
hi - the use of toothpaste works wonders on the head lamps...just use a large pea size....and gentle scrub with a tooth brush.....with some foaming....and finally rinse off.
this method has even appeared on youtube.
hope this has help.
