HEATED DOOR MIRRORS - HELP PLEASE
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Hi Guys
My E-class's heated door mirrors do not seem to be working - have checked through my handbook for fuse location, but doesn't show where fuse is. :mad: Could someone please post description / picture of location of said fuse.
Chassis no...WDB210 Avantgarde
REG DATE 07-01-2002
Many Thanks in advance
Malcolm
There no fuses for this, I think off hand its driven from the outside temp probe in front of the bumper,,, is the outside temp gauge working
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Hi Malcolm
Yes the outside temp is not working - on the dash it is showing the factory default of -38 degrees.
What is the fix
Cheers
Malcolm
The probe will have failed,, they are not expensive and they normally indicate 38 when bad :D:D
Just behind the bumper toward the passenger side
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Thanks guys - your help and advise is very much appreciated - looks easy to replace!!! - anyone replaced one?
Cheers
Malcolm
Loads have it was a very common fault a few years back
m.mycat
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Thanks Malcolm - In your earlier post I thought you said it was located in the front bumper!
It is dead easy to do just look under the front bumper :D I believe it just pushes into a rubber grommet. they are not very expensive to buy,,there might be some on Ebay, I have never looked for them
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Thanks Malcolm:D
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Just fitted the sensor - and started the car and no difference, however drove round the block and suddenly all started working - I guess it needed to re-calibrate or whatever. Anyway pleased with outcome - info for anyone who has the same problem...............
Part no of sensor A007 542 1318
Cost £13.40 plus vat
Thanks for help
Malcolm :D:D
