Heater matrix replacement help please
benzy007
London
C180 Saloon, 2001 petrol, manual
Hi guys,
Does anyone have the instructions for the replacement of the heater matrix please?
I know how to remove the dash panels etc... so no need for these to make it easier for you.
For a 2001 C180 (W203)
Thanks in advance.
As all of the center console has to come out, I have that info already that I can send, the final dash bit I can print off for you, it will be handy for those replacing flaps etc
B
benzy007
London
Thanks Malcolm.
I would really appreciate it if you could maybe email these to me, anything you have that may help me to replace the heater matrix.
My flaps are ok which has been tested on the mercedes star, so after checking everything it has been diagnosed with a collapsed heater matrix by the indie mechanic.
I can take the top dash off, glove box, radio console area, centre console, under steering dash panel, instrument panel.
Thanks.
OK wait till this evening and I will do it..
please just post again here so that it come up on new post later thanks
B
benzy007
London
When your'e ready Malcolm.
Do you need my email address?
OK I have all you need, the steering wheel and air bag we can deal with on here
Frontstep
T210 320cdi
These things wait for the cold weather, sounds a ball of wool best of luck and take pictures if you have a memory like mine.
I have forgotten what its like to have a memory:confused:
Frontstep
T210 320cdi
You have probably left a note of where it is somewhere, if only you could find it.
B
benzy007
London
Tell me about it!
I was thinking of doing a full write up if I do happen to replace the heater matrix myself, I will make an informed decision after I have a look at the instructions to help me understand how hard/easy it would be and if I should go ahead with the DIY.
Thanks for your kind words.
B
benzy007
London
Thanks Malcolm, much appreciated.
What would you rate the difficulty in doing this job after the dash panels etc... has come off?
Any idea what will be a reasonable quote from an indie to get the heater matrix replaced?
Thanks again.
I do need an address please and not that bad, just time
Air bag off, 2 x 30 torx screws behind the wheel
10mm alen key to remove steering wheel
The rest all unscrews
I cannot help on what someone would charge
B
benzy007
London
I tried to PM my email address to you Malcolm, but it didn't allow me saying your mailbox was full. I'll try again.
I really appreciate your help, I am willing to pay you for your time & effort, no offence intended.
Thanks.
I do not take bribes :D:D you can pop your address up here and edit it out soon, my PM box will never have a space
B
benzy007
London
Here's my email Malcolm.
B
benzy007
London
Malcolm, please let me know when you've got my email addy, so I can edit it out from here, thanks.
I am doing it now,,will post back
OK I may have sent more than you need,so ignore some, you can edit out your address now
B
benzy007
London
  • #19
Thank you so much for everything you have sent me Malcolm. It will definately going to help me a great deal, although I have taken the panels off previously the manuals will still help speed things up for me instead of guessing as I go.
You wouldn't have the manual of how to actually get to the heater matrix & remove it will ya?
Thanks again Malcolm.
Yes I will print off the actual heater part of the job later in the day :D
www.ckinsurance.co.uk
