Hello, Im hunting a Mercedes
kenobi
Ibstock, Leicestershire
www.htecelite.com
C200
Hi guys and gals,
Im Kenobi, I'm hunting a Mercedes c36.
If anyone can point me in the right direction, hints and tips for buyers etc.
Anyway looks like a good forum I shall have a good browse.
100%Bitch
Norfolk 'n' good
215 CL600, 216 Facelift CL500, 172 SLK55, Nissan Cube, R170 SLK230 & an Auto Trail Comanche.
Hi guys and gals,
Don't step on any twigs.
Seriously, good luck in your search.
MarkCL
Hampshire
W211 E320 CDi Avantgarde
Check the Pistonheads website, classifieds section (Mercedes, AMG bit) - saw a couple of decent C36's on there for sale recently though they wanted top dollar for them. All kind of depends on whether you're looking for a top example or a slightly rougher one you can bring up to spec.
Since they're early W202 models you should be ok for rust but keep an eye out - check the sills, arches and pull back the rubber on the top of the door frames. The engine is a nice smooth 6 cylinder - check for regular servicing and that it doesn't smoke etc. Usually they're pretty bomb proof though. Anything without good history and servicing records then walk away - doesn't have to be all main dealer (most likely won't be for that age of car in fact) but good regular services are a must. Brakes can be expensive so make sure they aren't so worn that they'll need replacing too soon - if so then you can use that as a bargaining point. Good luck :)
Cheers,
Mark
K
kenobi
www.htecelite.com
C200
Cheers,
Mark
TOP post thanks for ya help buddy.
Welcome to the forum. :D:D Is the Crown inn still there ??
Top marques and Exchange and mart have them from time to time
