cheers for that super fast reply many thanks
Thats not good for if you cannot get a drill in, its head off or engine out. Just as a tip for anyone doing this, the large aerosols of freezer work just as well as heat, as it is the shock that loosens the nuts[/quote]
As the actress said to the bishop!!
Heat tends to work better as the nut expands away from the stud....
HiHeat tends to work better as the nut expands away from the stud....
Hi I can only find nut so there must be studs broken of
http://www.detali.ru/cat/oem_mb2.as...GM=716.644&CT=M&cat=21T&SID=14&SGR=060&SGN=02
is this correct
You will have to drill them out using the manifold as a drilling jig with some custom made drill bushes then re-tap might need custom made studs depending on how they drill out no head our engine removal drill with one of these see pic
Kevin
sounds like mine!!!I will do it nowthe computer take 15 mins to warm up
