HELP - idling problems
Status
Not open for further replies.
william18
I recently purchased a 1970's mercedes which was going well until a couple of days ago. The problem started as I pulled up at some lights when the engine just stalled. Almost every time the car slows down to a halt the battery light comes on and it stalls. It's been running extrememly well for the last 6 weeks so I don't understand what could have gone wrong. Does anyone have any ideas?
Bill
Hal Fisher
Usually its either the Idle Control Valve or the Idle Speed Control Unit. Do some searches on these two things, there might be some info for your car model.
Hal
W
william18
silly question I spose but where is the Idle Control Valve? I've done some searches but couln't find any info.
N
nasher
You may need to add oil to the damper on the carb. The in laws MG had a similar problem, but was hard to restart as well. As winter's coming, should use ATF
Status
