help needed with a part name
joderest
ML270 2003
Dear All
There is a seal at the Turbo end of the pipe that goes to intercooler, a rubber seal, i suspect it may be leaking so want to replace it, any thoughts on what it is called ??
ajlsl600
france
ref description never can tel with benz but o ring seal would be fairly likely whats there or seal ring.
J
joderest
ML270 2003
or is the Turbo end just a jubilee clip seal, cant seem to find any seals listed for the turbo end.
A6420940080 , do you mean this one? (this is for the om642 engine , but it should give you the correct wording ) put the number into eBay
Bogus
Edinburgh
W124 230E 1992. BMW X3 2.0 d. X drive 2012
Thingumyjig, or whatchamacallit. Not helpful? Sorry, couldnt help myself.
J
joderest
ML270 2003
Bogus, you need help
J
joderest
ML270 2003
wighty.
Thanks, not sure, as v6 engine really not the same as 5 pot.
from everything i can see the Turbo end of the pipe is just sealed with a jubilee clip, but i am struggling to find a decent diagram to confirm this.
Oldspanners
Normandy
C CLASS 2004 C180
wighty.
https://mercedes.7zap.com/en/eu/fg/car/m-klasse/ml+270+cdi/06h/163113/m/612963/21t/14/0/030/0/0/
Is this any use not sure what part you need but click on the part number in the diagram and it will give you the part number and description. IF I have given the right link.
J
joderest
ML270 2003
erm, made a slight error, its the pipe that goes from air cleaner to Turbo, Thanks OLDSPANNERS, think i have worked it out now, there is a "spacer", not sure if its a seal, gives me a start.
cheers
J
joderest
ML270 2003
Thanks to OLDSPANNERS found the seal, part number A6120940051 engine turbo seal.
It was only £5 delivered, so hope right bit.
Thanks again all
Jim2
J
joderest
ML270 2003
it is handy, very good, thanks
