Help needed.
pitponyman
pontypridd/rhondda/wales UK
Old Hymer camper using Mercedes 310/1987/2.3 petrol
I have an 1987 Hymer motorhome. It has a 2.3 petrol (carb) engine. It starts easily but only runs for 30 secs or so. Thought it might be fuel supply si rigged up a gravity fuel supply. Made no difference. Where do I start?:(
wireman
lancashire
My immediate suspicion is a fuel blockage in the carb's inlet pipe or the valve in the float chamber.
To where did you connect your gravity supply, was it directly to the carb?
Can you identify the carb type, a photo might help somebody identify it?
Does it re-start straight away or is a wait involved?
Vamps
Durham
Jeep Grand Cherokee
Not helpful sorry, but so nice to see a post than mentions the word 'Carb' .....:p:p
cleverdicky
MB
Sounds like the needle valve might be sticking closed. (attached to the float)
Whip the head off the carb and have a look to check the float is free and not sticking.
P
pitponyman
Sick Hymer
I connected the fuel supply directly to the carb. Ok I now have a starting point. Thanks all you greater minds. I suspected fuel as I bought it as a non runner. The last owners had overheating probs in July. Local garage said head gasket. There is a bill for removal of engine, strip, sort head and rebuild/refit. Apparently its been a bit sick ever since and ended up as it is now. A different mobile mechanic had a look told them it needed a new carb quoted £800 and drove off into the sunset. Nice people gave up and advertised it. Along I came. As a pensioner I don't have a lot of money to spend and have forgotten a lot of my car repairs over the years. So stiff in me body I struggle a bit but quite like the challenge.
I will get to the carb and see what I see. At least it a carb and not electronically controlled wizardry. Thanks lads.
brandwooddixon
Wolverhampton
S63 Coupe 2014
I would suspect that 30 seconds is longer than it would run for with just float chamber fuel.
Any idea what carburetter it is?
As wireman, can you restart it immediately after it stops or must you wait for a minute or so?
What sort of head does your gravity, fuel feed have?
As well as fuel starvation it may be worth checking whether it is overfuelling, say with a stuck choke flap. On full choke the engine won't idle for long when warm. Take out the plugs and have a look, are they wet?
wireman
lancashire
It might be a Pierberg electronically controlled wizardry carb.
brandwooddixon
Wolverhampton
S63 Coupe 2014
Don't those have a temperature thermister to control fuel mixture?
Cheap and simple fix if it is.
P
pitponyman
Took off the air filter. Started from stone cold easily. runs well, revs up and ticks over ok. Just goes a bit rough and stops after 30 seconds or so. Won't restart. leave for 10 mins, starts but stops again possibly a bit sooner. Tried to restart it on easi start sprayed into the carb air intake. Won't start? ? ? ? ?
P
pitponyman
There is so little space I can't yet see. Looks like a nightmare to take it off the motor, there pipes and wires everywhere. Last resort I think. Wiki says Stromberg CD150. but this looks like a downdraft carb.
P
pitponyman
It won;t restart very soon I guess 5 or 10 mins.
Can't see what the carb is. Its a downdraft with several wires and pipes to it.
Only about 6 inches from a pop bottle down to the carb. As it has a flow & return fuel pump system I didn't think it would need much.
From stone cold it starts well revs ok and idles. It's not choking to death. Goes a little rough (missing) and stops.
Frontstep
T210 320cdi
Can you remove a spark plug ?
I think its likely to be black and sooty, if it is sounds like a choke sticking problem to me.
A few pictures would be helpfull if you could to identify things.
P
pitponyman
Have some phone pics and a video. Runs for 27 seconds. How can I upload them?
P
pitponyman
  • #19
Spark plugs
The [lugs are a nice brown colour. Do I remember that a faulty condensor can give this type of fault? I presume this is pre electronic ignition and has points etc.
Frontstep
T210 320cdi
Good, are all the pipes to the carb in good order if they are I suggest a strip down and clean.
