HELp ..w210 engine no power
andrew lim
my car is w210 v6 e240 112engine.....my car when rev..the engine slow respond.....i just top overhaul engine....because overheating last time...
now a mechanic repair or change any part....trotthe body ....air mass sensor...fuel pump....and check a engine timing.....but now oso a same thing.....so please !! HELp me!!...
dieselman
A diesel
If it was Ok before the head work, now it's not then it's something you've done.
Go back and check the cam timing, then look for air leaks.
A
andrew lim
thanx...diesel man.......if i kickdown a pedal,the power ok!...only when i drive 4gear to3rd gear a little bit hard....is a valve body problem??........cam timing and leak air...checked...is ok bro....
